Driver'side power window problem
After changing the alternator and battery on my 2003 6, none of the windows worked. I read how to reprogram them. Now the two rear and the passenger' window work both from the master control on the drivers door, and from each winow's switch. The only window not working is the driver's window.
I thought the motor was burned out but before buying a new one, I took the rear right window motor out and tried it. The motor didn't work. I then hooked up the motor I thought was no good to the rear right window switch and it worked. So this told me the motor is fine. I figured the master switch was shot even thought he other three windows controlled by it work. I got a new master switch but that did not fix the problem. It seems like there is no power going to the drivers window motor. Not being at all familiar with auto wiring I am not sure how to fix this. Any suggestions would be greatly appreciated. Thanks, BBB |
