Car is making loud blowing sounds behind the backseat
Old Feb 17, 2010 | 11:05 AM
cluelessgirl's Avatar
Default Car is making loud blowing sounds behind the backseat
My car is making loud blowing sounds behind the backseat, behind the back passenger's head, right under the windshield.
I turned off the heater and the radio, and it still continues to make the loud blowing sounds ... it's not a hiss, just a really strong blowing sound.
Can anyone please tell me what it could be?
The car is driving fine, but the sound makes me worry. Thanks.
Old Feb 17, 2010 | 01:27 PM
AHan's Avatar
I assume it's a Mazda 6. What year and model?
Does the sound get louder with a higher rate of speed? Does it happen at idle? Need a little info to go on.
Windshields are in the front.
Old Feb 17, 2010 | 01:54 PM
yes, it's a mazda 6 ... year 2003 ... um, i don't know which model
no, the sound doesn't get louder with higher rate of speed
yes, it happens at idle
sorry, i didn't mean to say windshield ... i am referring to the back glass window
the sound is just a continuous blowing sound without hissing ... there isn't any wind coming out ... just the loud blowing sound ... sounds like a house furnace heater when its blowing air out ... but i don't understand why the car makes the sound even when I have the heat turned off
thanks and i appreciate any advice
Old Feb 17, 2010 | 02:22 PM
AHan's Avatar
A couple of thoughts.
One, I assume you are turning off the blower/fan, not turning the thermostat down?
Two, you had the fan relay module recall taken care of? Could be a fan noise from under the hood, but you may hear sond reflected from in the compartment? Try listening with the hood open from outside the car.
Three, disconnected vacuum hose? Same as two, listen under hood.
Old Feb 17, 2010 | 10:00 PM
Strangely and thankfully, the car didn't make the sound when I drove home tonite ... hopefully, it was just a one-time thing ... thanks AHan !!!
mazdaidk
Apr 9, 2014 08:49 PM
Kasstastrophy
Jan 24, 2009 05:12 PM
Mazda929Driver43525
Mar 13, 2008 11:28 PM
cksy
Mar 20, 2007 01:28 AM
