V6 5 speed shifting problem!
Old 03-18-2018, 07:50 AM
kinz1987's Avatar
Default shifting problem!
Ok so I just bought a 03 Mazda 6 3.0. While driving in normal conditions for some reason the shifter stopped going into gear. It will move left and right while in neutral, and it will move up into 1st, 3rd, and 5th. But just enough to barely touch the gear, the second I release the clutch it will pop out. And 2nd, 4th, and Reverse I can’t even get to, the shifter will not pull back at all. Can someone please help?
Old 03-18-2018, 08:00 AM
shipo's Avatar
Can you shift into any of those gears when the engine isn't running?
Old 03-18-2018, 08:03 AM
kinz1987's Avatar
it doesn’t matter if the engine is running or not. The problem stays the same.
Old 03-18-2018, 09:14 AM
shipo's Avatar
Then it sounds like your shift linkage has been compromised in some fashion. This isn't something which can be diagnosed on the internet.
Old 03-18-2018, 10:28 PM
kinz1987's Avatar
Ok so I pulled a few things apart. The cable that is moved when the shifter is moved front to back seems to be limited in motion. Does anyone know of a simple fix or do I have to replace them?
Old 03-19-2018, 05:39 AM
Disconnect the shift cables off the transmission & try to change/select all the gears.
Let us know how you get on.
Old 03-19-2018, 08:19 AM
kinz1987's Avatar
That’s what I did. I first pulled the cable off the shifter and made sure the shifter has a full range of motion (it does) then I disconnected it from the transmission (and the trans seams to be fine). With it disconnected from the transmission it’s limited (just kisses 1st, 3rd, and 5th) and it will not go into 2nd, 4th, and Reverse.
Old 04-01-2018, 08:41 PM
kinz1987's Avatar
JUST TO give you guys an update. The plastic guide on one of the shift cables near the transmisson (under the rubber boot) I replaced the cables and now I’m on tothe next problem.
cebailey
05-30-2010 01:38 PM
littlebitt
10-02-2008 12:12 PM
Spike_Wolfe
03-01-2007 06:15 PM
trips
10-29-2006 05:12 PM
shockster
05-17-2006 10:00 PM
Quick Reply: V6 5 speed shifting problem!
