2014 Starting Problems
2014 Mazda 6 Grand Touring. Multiple
instrument light including "keyless inspection system inspection required" and "SCBS System" issue come on, dials flutter. Car starts with jump, but battery tested fine in all aspects. Cleaned contacts due to corrosion, but problem happened again, jump worked again. Don't think it's alternator since it continues to run with negative disconnected. Any suggestions? |
Who tested the battery, and how was it tested?
Never ever disconnect the battery with the engine running, you risk damaging several thousands of dollars of electrical modules. |
