2008 Mazda 6 engine swap
Old Oct 17, 2017 | 08:21 AM
Pontiac730's Avatar
Question 2008 Mazda 6 engine swap
Hi
I have a 2008 Mazda 6 with the 2.3 non turbo and I have a 2006 Mazda 2.3 low mileage. And I am told the engines will not interchange
is it possible with and modification or parts swapping that they will interchange
any help would be appreciated especially since the engine I got was free and I seen it run beforeit was pulled out of donor car
Old Oct 17, 2017 | 12:31 PM
shipo's Avatar
I may be mistaken, but if you pull all the accessories off the 2008 motor and bolt them up to the 2006 motor, you should be able to make it work.
The above said, if you're pulling a 2.3 motor, there is no way I would ever put another one back in; the engine has a very poor reputation for longevity. Were I in your shoes I'd spend another $500 and buy a nice low mileage Ford Duratec 2.5 liter motor and put that in instead; the motors are virtually identical externally, however, the Ford motor is more powerful, just as fuel efficient, and has a very good reputation for longevity.
Old Oct 17, 2017 | 01:32 PM
Pontiac730's Avatar
What will I have to change if I go with the Ford 2.5 duratec engine wiring etc.
Old Oct 17, 2017 | 01:47 PM
shipo's Avatar
Pretty much the same stuff as going to the 2006 engine; remove the manifolds and sensors from your old engine, bolt them to the new engine, and install.
KBJ!MP5
Apr 7, 2015 01:22 PM
Mags
Aug 7, 2011 01:05 PM
fobmasteralex
Jul 20, 2009 01:46 PM
jdk
Jan 20, 2008 09:59 PM
Herblenny
Jan 14, 2008 08:53 AM
