2005 Mazda 6 AC recharge, low/high r134a pressures?
Old Aug 30, 2014 | 10:13 PM
Mazda6xav's Avatar
Default 2005 Mazda 6 AC recharge, low/high r134a pressures?
Hi,
Does anybody know for sure the low/high pressures that we are supposed to read on the AC system for a 2005 Mazda 6? I have a curve pulled from a workshop manual but I am not sure how much I trust it since it states there should be 16.8 oz of R134a in the system, where the engine compartment sticker shows 1.1 lbs (17.6 oz).
I vacuumed the whole system for 45 min with no leaks, then added r134a with the gauges on and 1500 rpm. I got to about 30 psi / 250 psi by adding 2 cans (12 oz each) 85-90F ambient. I know I didn't quite get the full 24 oz in, but the cans were pretty much fully empty when I was done with them (no more liquid inside). But even accounting for a loss of 2-4 oz in the lines + purging the lines from air! I am still overcharged but still not quite meeting the high pressure for the high side and a bit too high for the low side per the chart. (Max 23 low side, min 260+ for the ambient).
So I am not sure if the data I have is right for the pressures.
Thanks.
Old Aug 31, 2014 | 03:30 AM
2005 Facelift Australian Spec Mazda 6
Item Specification REFRIGERANT SYSTEM
Refrigerant Type R-134a
Regular amount L.H.D. 470gms {16.6oz} R.H.D. 430gms {15.2oz}
BASIC SYSTEM
A/C compressor Lubricating oil Type ATMOS GU10
Sealed volume 150ml {150cc}{ 5.07oz}
CONTROL SYSTEM
Magnetic clutch Clearance (0.3-0.5mm {0.0122-0.019in}
Old Aug 31, 2014 | 05:45 PM
Mazda6xav's Avatar
Thanks grim reaper but I am really looking for the pressures I should be seeing on the low and high side when running at 1500 rpm. The r134a qty is listed in the engine compartment so I'm pretty sure the 1.1 lb (17.6 oz) is right.
RogerMT
May 28, 2013 05:08 AM
Fireman27
Jan 10, 2012 02:30 PM
tony56g
Mar 9, 2008 04:06 PM
surrealistic
Apr 23, 2007 02:53 AM
elfion
Jul 31, 2006 02:16 PM
