2004 Mazda 6 3.0L - Starts then Immed Stalls
Old Apr 24, 2018 | 12:41 PM
Joseph Spielman's Avatar
Default 2004 Mazda 6 3.0L - Starts then Immed Stalls
Need some help. 2004 Mazda 6 - Starts then Immed Stalls . Just got a fuel pump from junkyard and put in. Spark plugs and ignition coils three months old. Car was on highway and just lost acceleration now wont stay running.
Anyone know where fuel filter is located? its a mazda 6 wagon.
Old Apr 25, 2018 | 12:29 PM
kinz1987's Avatar
You get this sorted out?
Old Apr 25, 2018 | 07:10 PM
not yet.
Old Apr 25, 2018 | 07:37 PM
kinz1987's Avatar
Ok. Are there any engine codes? And was there any kind of odd noise when I died?
Old Apr 25, 2018 | 07:39 PM
kinz1987's Avatar
And I believe the fuel filter is under the car, under where the center council is (between the frame rails). If it wasn’t pouring rain I would check mine.
Old Apr 25, 2018 | 08:08 PM
I had a P0431 for the longest time. No egg smell, No noises.
Old Apr 25, 2018 | 08:09 PM
Pretty sure filter is part of the fuel pump.
Old Apr 25, 2018 | 08:13 PM
Things I changed over last six months:
EGR Valve
MAP Sensor
CAM Sensors
CRANKshaft Sensor
Spark plugs
Ignition Coils
Mass Air Flow Sensor
Throttle Body (Cleaned)
Fuel Pump
Old Apr 26, 2018 | 08:07 AM
kinz1987's Avatar
As the code description implies the P0431 code means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem. If the P0431 code is combined with other codes, try fixing the other codes first.
This is what pulls up when I typed in the code. you could have a plugged up catalytic converter.
Old Apr 26, 2018 | 08:21 AM
kinz1987's Avatar
Here's a link to check to see if that's what it is.
