2003 Mazda 6 with 2.3L
Here is the scoop- Car idles rough at times, jerky at low speeds on occassion and generally acts like there is a vacuum leak. Took it to Mazda and they say it is the purge valve. Did not have it in stock. Did my homework and hunted down the purge valve and manually applied 12v to the solenoid and it opened and closed as it should. I replaced several vacuum hoses as they were cracking but still no better. Where do I go from here? BTW, I have already replaced the gas cap, just to eliminate that possible issue. Any ideas are appreciated, and yes I can go to AZ and get the DTC code again but thought I would present here first. THX
Update
Ran by AutoZone and had the codes read. They are as follows- P0456-EVAP system leak detected; P2187 Fuel system too lean at idle-right bank. Things that have been done- replaced fuel cap, spark plugs and plug wires. And as previously stated, checked the purge valve and it performed properly. There are lots of hoses to check but any other suggestions are appreciated.
Try this, but don't make it a habit!
Thanks for the idea tanprotege. It did help me confirm that a few questionable vac lines are still holding vacuum. My concern after all this is that the PCV valve/line may be leaking or not working properly. As I cannot get to either without removing the intake manifold, I sprayed some carb cleaner between the openings in the intake and behold I got a slight change in RPM's at one point. I am assuming there may be a vac leak there. Question- is there a way to check the pcv valve aside from removing all thats required to visually inspect the pcv valve?? Thx
Originally Posted by Gmanpumps
(Post 134586)
Vacuum update
Just came in from the PCV valve replacement on my 03 Mazda 6 with the 2.3L engine. What a pain but indeed the PCV line was split!! Replaced it and the valve and will hope for the best. No CEL yet but only driven it a few miles. Seems to be running smoother. Learned a lot, probably could cut the time spent in half. If there is someone going thru this now, feel free to respond to this thread and I will do my best to pass on the any help. BTW thanks for the push Noggin!!
Nice going, Gmanpumps!
I know what you mean here: "Learned a lot, probably could cut the time spent in half." |
(Post 134758)
J What a pain but indeed the PCV line was split!! Replaced it and the valve and will hope for the best. No CEL yet but only driven it a few miles. Seems to be running smoother. Learned a lot, probably could cut the time spent in half. BTW thanks for the push Noggin!!
Things must have been carboned up, gummed up. Put in some fuel system cleaner. |
I'm about to replace it tomorrow. Any tools that I should be looking out for? Or any specific parts I should be buying for the PCV and the line?
I only have the basic wrench at the moment but I'm probably going to be buying more in the morning. |
For a 2.3 Mazda 6 you will need 1/4" socket set, Flexi magnet.
It would pay to replace the o-rings/manifold seals too. Its a pain in the arse job. When you go to refit the manifold, pack a bit of paper or tape around the bolts so they are a tight fit in the socket when you go to refit them. You will understand why later. |
| All times are GMT -5. The time now is 04:12 AM. |
