2003 6 intermittently won't start
Please help as my girlfriend is giving me tons of crap for this.
I checked both the battery and the alternator with a voltmeter and the readings are good. I'm sort of confused at what the problem could be. I thought that maybe it was an ignition coil, but then the engine would run bad when on and that's not the case so i ruled that out too. the only thing i can think of is the remote car starter that's installed and i'm having best buy check that. any other ideas???? any help would be greatly appreciated. p.s. a quick jump with cables will fire the engine up with no problems, but then why would the battery look good with the voltmeter???? |
RE: 2003 6 intermittently won't start
How old is the car? Sounds like you need a new battery.
Voltmeter will only show 12 V., but it won't show Ampere (the # of units of 12 V. it can supply). You know 8 AA linked up to make 12 V (1.5 X 8 = 12) won't start you car. Have your battery tested at a shop. |
I see that it's a 2003. I'll say your battery has served fairfully for the past 5 or more years. Time for a new one.
