-   Mazda6 (https://www.mazdaforum.com/forum/mazda6-20/)
-   -   06 mazda 6 2.3 (https://www.mazdaforum.com/forum/mazda6-20/06-mazda-6-2-3-a-29450/)
smithtowing2008 Jun 2, 2012 05:28 PM
06 mazda 6 2.3
i just bought this mazda 6 2.3 i was driven today and it died and would not start had it towed to the house ran the codes and i had a po 340 cam sensor code so i replaced it and still no start, checked for spark and it only sparks the spark plug one time.
UseYourNoggin Jun 2, 2012 06:16 PM
Try crank position sensor. Both cam and crank are reliant on each other.
"The most serious indication of CPK malfunction is intermittent start, and eventually no start"
Read more: Crank Position Sensor Symptoms | eHow.com
"These sensors are often located behind the harmonic balancer and can easily become contaminated from hot engine oil or coolant."
"The symptoms of a faulty crankshaft position sensor include no start, intermittent start, and poor engine performance. This is because this sensor effects fuel and ignition timing."
FROM: Troubleshooting Crankshaft Position Sensor Problems
This shows procedure and diagram for your vehicle: Mazda 6 I I need to replace the camshaft position sensor on - JustAnswer :eek: (scroll down).
smithtowing2008 Jun 4, 2012 08:09 AM
i just replace the crank sensor, still doing the same thing u thank it might be the ecu
UseYourNoggin Jun 4, 2012 08:32 AM
Wow, you never know. Out of ideas. Take it in to a shop.
grim_reaper Jun 8, 2012 07:36 AM
Fuel pump failure is common on older Mazda 6s.
tanprotege Jun 8, 2012 04:14 PM
A bad fuel pump should not cause a lack of spark.
Smith: did you check all the power and ground connections related to the ignition and alternator? Did you check the spark plugs, wires and coil pack?
If all of that is good it may well be the ECU.
