-   Mazda6 (https://www.mazdaforum.com/forum/mazda6-20/)
-   -   '03 AC Problem (https://www.mazdaforum.com/forum/mazda6-20/03-ac-problem-29460/)
kls629 Jun 4, 2012 02:07 PM
'03 AC Problem
I just noticed last week I am unable to switch the air conditioning from "Outside Air" to "AC (circulated air)"
The LED above the Outside air is on, but when i push circulated air nothing happens.
The outside air is cold but not as cold as circulated would be. I called the dealer and to check for the problem is around ~$109. With summer coming i am nervous and dont want to fork up a lot.
Anyone else ever have this happen? Hopefully its small problem
tanprotege Jun 4, 2012 04:59 PM
I had a similar issue with Ford Windstar. There should be a baffle in the ducts that closes off the outside air and opens the inside air return duct. I am guessing that this baffle is operated by a little electrical motor unit that Ford calls "blend door actuator". You could call a parts store and ask if they have such a thing for your car. Or search google how to replace that beast. If you are lucky a connector has fallen off...
