Tire size and rims
1 Attachment(s)
Have a 2013 Mazda five just put 18 inch rims with 225/45/18 size tires. they rub when I make turns and they will rub if I hit a pothole . Should I go smaller size wheel or smaller size tire what will work |
Assuming your wheels have the correct offset (45mm to 50mm), you should be running 215/45 R18 tires. The tires you're running are both slightly wider and slightly larger in diameter. If the offset on your wheels is incorrect, then all bets are off.
If I change 17x7 what size tire should I get with stock suspension |
The stock tire size for your car is 205/50 R17; you can also run 225/45 R17s for a little extra width.
Im running 225/45/17 on factory 17"s on my 2012. No issues.
17x7 ? |
Either 17"x6.5' or 17"x7" I'm not 100% sure.
You need a offset of 45 to 55. Factory BL rims range from 48 to 52.5 offset |
17x8 think will be too big? |
Thank y’all for all the help |
