Passenger side fuse panel
Hi,
I have a UK (RHD) Mazda 5 and need to find the Air Conditioning fuse. The handbook says it's in the passenger side fuse panel but I can't find any fuse panel in the passenger side footwell. There's a panel above the glove box but I think this just houses the ECU (I'm guessing here - all I can see is a black box with a block connector plugged into it). The handbook has a diagram of how to find the engine compartment fuse panel (very helpful but not the panel I'm looking for). Any ideas where this panel is? Cheers, Phil |
Found it!
Eventually I found it. It's just above the passenger door hinge but crucially you can't see it unless the passenger door is open (open the door fully and there's a black panel marked 'Fuse Panel' above the door hinge).
Unfortunately the A/C fuse is in tact which means either my 5 needs re-gassing or something's wrong with the A/C system :( |
