Oil leak on top of oil filter
Old Nov 12, 2011 | 09:25 PM
Jessev's Avatar
Default Oil leak on top of oil filter
Hi guys,
I was hoping someone would know how to advise me on a little oil leak problem of mine. I have a 2006 Mazda5 Sport. I noticed a while ago that my car was dripping just a little bit of oil on my driveway. I lifted up the front and found that the leak is coming from the top of the oil filter (or in this case the housing for the oil filter) right between the oil filter and the black box on top of the filter where coolant runs through. I'd like to fix this myself if it's a fairly simple task.
Please let me know if you know how to fix this.
Thanks so much.
Old Nov 13, 2011 | 07:03 PM
If its coming from the oil filter adapter, that cast metal piece that is the go-between the engine and filter itself, they use a metal crush gasket that can be had at the dealer. Or, you might just try removing it and using some RTV silicone on it.
Its held on with 3 bolts and is not hard to remove... or it wasn't in my case when I converted to the spin-on filter of the 2.0L engine. It required changing the entire housing.
Old Nov 14, 2011 | 10:57 AM
lnwlf's Avatar
Am considering switching to the screw on filter myself... it seems like it would be pretty basic, could you offer a heads up on how make the switch?
Old Nov 14, 2011 | 12:24 PM
Sure! Easy!!
Buy the new adapter and gasket. Remove the splash shield (or loosen if you are brave) and plastic filter housing and allow to drain, remove the oil sending unit wire and three (correction, FOUR) bolts that hold on your current filter adapter, transfer the oil sending unit to the new adapter, bolt on the new one using the new gasket, clip on the oil sender wire, put on new spin-on filter of your choice... primed please.
Done!!
It took me about 1/2 hr including time to drain and wipe off the excess oil.
*edit* Here's what you need and where/one place to buy it from: http://www.mazdastuff.com/product.cfm?ProductID=2869
Old Nov 14, 2011 | 08:11 PM
lnwlf's Avatar
excellent! much appreciated!
Old Nov 15, 2011 | 04:16 PM
No problem.
It does make changing oil a lot easier and a lot less messy.
I was always afraid the plastic housing was going to crack and I had stripped out its soft aluminum "drain plug" at least a year before that. I am glad to be rid of it.
BTW: If you want an excellent filter for it, use WIX #51348. They can be had @ Amazon.com or under the NAPA Gold number @ Fleetfilters.com
Old Nov 15, 2011 | 06:15 PM
lnwlf's Avatar
Why they made it out of plastic I'll never guess... had to replace mine once already because I cracked it... guess I should be careful of my super human strength.
Old Nov 23, 2011 | 03:11 PM
deadwood's Avatar
I just went through this mess. 2007 Mazda 5 with 107,500 miles and 6 months out of warranty.
The seal between the oil cooler and the filter housing began to leak, bad. I pulled it all apart and expected to go down and pay $5.00 for a new seal but was told I need to buy the whole new cooler for $435.
I had no choice but to buy one. I wonder if the seal on this one is replaceable?. Fortunately I was able to install it myself and save the labor costs.
My advice: if you have a Mazda 5 with one of these old style installed and it is still under warranty, put a wrench on the nut that holds the cooler to the filter adapter and loosen it just enough so it leaks. Take it back to the dealer and make them fix it with the new cooler. Otherwise you will eventually have to do it yourself and pay for it.
In the attached photo you can see the new one on the left, the old one in the middle and the old seal on the right. The new one is easy to identify as it is a silver color and the old one is black.
Old Nov 23, 2011 | 03:48 PM
My god!! If they tried to charge me that much for a factory oil cooler I think I would've come up with an alternative.
Can it be removed and bypassed?
If so, why not install an aftermarket cooler in front to the radiator and redirect the hoses?
Old Nov 24, 2011 | 09:48 AM
deadwood's Avatar
All those options went through my mind, but my daughter needed the car back ASAP.
One could put the filter adapter from a 2.3 engine that does not have the cooler on (Mazda 3?) and then just plum the two coolant lines together. You would loose the cooler but with as small as it it I'm not sure how much good it does. Or, as you suggest find a way to plum in an after marker cooler. All these options would take time and money though.
I'm wondering if a nicely worded letter to Mazda customer service might help me get a refund on the cooler.
