Mazda 5 C1288
Mazda 5 C1288
Hi all, my car mazda 5 2007 2.0 is showing fault code C1288 Pressure Transducer Main / Primary Input Circuit Failure, no warning lights on my dashboard. Do you guys know the how to fix this?
C1288 in the workshop manual is for the DSC HU/CM (ABS pump)
Description is " The voltage value from the brake fluid pressure sensor is not within specification."
Recommended fix is, clear the code, go for a drive, if the code comes back replace the DSC HU/CM (ABS pump).
