Hot Rod Parts
Old Feb 14, 2011 | 01:13 PM
my2012M5's Avatar
Default Hot Rod Parts
Is there anyone out there knowing of performance parts to fit the 2012 Mazda 5?
Old Feb 14, 2011 | 01:48 PM
shipo's Avatar
You mean like a turbocharger setup or something?
Old Feb 15, 2011 | 10:32 AM
lnwlf's Avatar
You may want to try looking for Mazda 3 parts as many of them will fit.
Old Feb 15, 2011 | 05:11 PM
MazdaFan12's Avatar
Default Turbo? Cosmetic?
My question is the same as Shipos. Turbo? Cosmetic?
Old Feb 15, 2011 | 06:20 PM
Sure! As lnwlf has said, most parts that fit the 3 series also fit the 5, though rear spring rates are a bit higher on the 5, so springs design to fit a Mazdaspeed3 would be the way to go. For example, I know the Koni FSD system for the MS3 is the same as it is for the 5 series.
Other than that, have at it with shock, struts, sway bars and coilovers that fit the regular 3 series.
Old Feb 16, 2011 | 09:24 AM
my2012M5's Avatar
Default Parts
I want to get cold air induction, header pipe, and a cat back dual tip exhaust for right now. I had toyed with the idea of a turbo, but I want to be sure I can get better axle ratio and limited slip like device. I have never tuned Mazda's, but I did hear about the similarities with the 3's. The car is a 2012 and there arent any in a 3 yet, so I didnt know if the parts would swap. I do want suspension too, so those suggestions are appreciated.
Old Feb 16, 2011 | 10:20 AM
lnwlf's Avatar
as with all new model vehicles, after market parts will be a little slow coming out. but as long as the 3 and the 5 use the same engine the parts will fit with the exception of the exhaust. it can be modified to fit but will probably be cheaper to find a good exhaust shop and have them make up a custom exhaust for you. what brand of header are you thinking about? from what I hear Vibrant is the way to go, may cost a bit more but worth it in the end. I believe the stand alone ecu's will be compatible as well.
Old Feb 16, 2011 | 10:43 AM
lnwlf's Avatar
as far as the turbo... if you have an automatic... don't even bother unless you want to spend $3000-$4000 to beef up the tranny, that's on top of the $3000-$4000 for a turbo kit. I think, (my opinion) the best way to go would be to find a speed3 that has been wrecked with a good engine and tranny and swap everything over, to include the ECU. then you would have a speed5.
http://www.caranddriver.com/features..._5-project_car
JBH_STL
Aug 5, 2007 01:37 AM
Mazdaboy2600i
Apr 19, 2007 02:33 PM
MAZDAMANIA
Jan 14, 2007 12:58 AM
swoopes_30
Jun 19, 2006 09:14 PM
soupy
Nov 1, 2005 07:06 PM
