Dpf sensors
Hello everybody,
I have got a problem with my dpf. I had to remove it, but i broke 2 temperature sensors on 3. The HO2S sensor is ok. I can't find the replacement reference for the sensors. Can anyone give me the reference? My Mazda is a 2007 2.0 mzr-cd 110hp. Thanks |
Oxygen sensor
Hi there
I think I have the exact same motor like yours mine is an import thou and I'm struggling to get the correct part ....I need an oxygen sensor but my vin number is not helpful . Can you maybe assist me I have a 2007 Mazda 5 import vehicle ....my radio is also in japeneese lol |
Hey,
if your engine is a 2.0 mzr cd, you can find the oxygen sensor refs here: https://m.auto-doc.fr/denso/7887802 where you from? Cheers |
I am from South africa Capetown ....on the engine cover it says Mazda 2.0 mzr DISI so not sure I am new to Mazda ...I managed to find one at masterparts with the correct pin outs and plugs but the voltage was to high I then returned it
Sure it's the same engine. Check the link i sent, you Can find loads of refs according to your engine.
check the connectors. Original parts are denso parts. You may find your sensor. |
