Cruise control for Canadian Mazda 5 GS / Cabin Filter.
Hello all,
Here in Canada the cruise control is not even an option for the GS model. Has anybody out there searched for aftermarket solutions ? Is it "technically" possible to install the cruise control module from the GT model into the GS model. Also, does anybody know where the cabin air filter is located ? Regards, Daniel |
RE: Cruise control for Canadian Mazda 5 GS / Cabin Filter.
Hello
I bought a Mazda5 GT 2006 two months ago. While talking to the dealer at time of purchase, he told me it was possible to add the cruise control on the GS model at time of delivery. If you need more info, your dealer should be able to help you. Good luck |
Thanks,
My dealer said "No" when I bought the car.... I will try other dealers. |
Your dealer either does not know what he is talking
about or he is too lazy to find out. All Mazda 5's come with the wiring harness in place and the computer programmed to run a cruise control. All that is required is about one hour of labor and two components. One is the steering wheel mounted controller and the other is a different brake switch. If these are installed you will have a factory cruise control on your 5. Cheers, Robin |
mazda cruise control
I purchased a 2008 Mazda 5 GS and when I got it home my wife asked where the cruise control is. To my astonishment a GS has no cruise. I called the dealer and asked why they forgot to tell me. Had I known this I would not have purchased the vehicle because I always use cruise. Their service adviser used to work at a Mazda dealership and put me in touch with a friend at that dealership in Chatham Ontario. It took them 10 minutes plus a 10 minute test drive and I had cruise. It cost me $320. Well worh it and it is the same as factory installed.
Originally Posted by DurhamProPhoto
(Post 27426)
Cruise swap on 2010 Mazda 5
Originally Posted by mazda5June152019
(Post 177567)
Thanks Robin. I bought my 2007 Mazda 5, which did not have a cruise control, in June of this year. I took a cruise control switch off a wreck at PicknPull but it didn't work until I changed the brake switch which you suggested in your post of 2006. The replacement brake switch had 4 leads instead of the 2 leads on the original.
(Post 27426)
