Alarm goes off
When we try to open the door manually with the key the alarm goes off . Does any one else have this proble?
What happens when you use the remote?
What brand of alarm is it? Did it used to go off when using the key? |
(Post 165649)
What brand of alarm is it? Did it used to go off when using the key? It is the factory installed alarm, the remote works fine you just can’t physically use a key. Only tried using the key once before and that’s when the battery was dead in the remote . Replaced the battery and was curious if I could use the key. Nope alarm goes off, so have to use the remote. |
Then that is completely normal.
The Alarm is controlled off the remote, not the door locks. |
