#4 plug missing electrode
Old Aug 9, 2020 | 05:02 AM
ThorOtheBIG's Avatar
Default #4 plug missing electrode
Been on the same set of Denso Iridium TT spark plugs for the past 40k-50k miles, about 2-3 years. The car now has around 95k and I am freshening things up. The #1 cylinder spark plug's electrode looks round, like a sphere or tiny ball bearing. The #4 is missing its electrode tip. It explains the extra rumbles when A/C is on and what seemed like a very slight misfire or hesitation that happened very infrequently. Obviously, those went away with the new plugs (NGK Ruthenium HX, also twin tip).
Did a compression test while I was there and especially due to the damaged plugs. Cylinders #1 and #2 had 189. Cylinder #3 is 191. Cylinder #4 is 192. All held their compression fine.
The only culprit I can think of is maybe the intake tumbler flaps are not functioning properly. I've been wanting to run some tests on that system for awhile. I know I can test the vacuum components for this system and the actuators, but I don't know how I can visually inspect the flap conditions.
I can post higher quality pictures of the damage plugs, if requested.
Denso Iridium TT after 40-50k miles/2-3 years
prestodude
Sep 13, 2015 07:04 AM
paqman
Jul 6, 2013 09:49 PM
windbk
Feb 4, 2013 05:11 PM
JKoolMann
Nov 15, 2007 07:24 AM
