2016.5 CX5 electronic parking brake
Old Jun 14, 2022 | 08:44 PM
Dpthom's Avatar
Default 2016.5 CX5 electronic parking brake
I accidentally pulled the electronic parking brake (EPB) while at approx 30mph...there was a some noise, a clunk - obviously - and it wasn't a pleasant experience. Since then EPB still works but the right and left rear brakes seem to operate at a different speed when I disengage the brake from a stop. What would be the most likely type of damage that could have occurred. Is there any way of checking this myself before taking into a shop for a check up?
Thanks,
Old Jun 15, 2022 | 06:45 AM
Unlikely related, but they are known to have issues with uneven disengagement. There is a tech bulletin in my market, and I would assume so for the USA.
Old Jun 15, 2022 | 07:42 AM
Dpthom's Avatar
Thanks so much....can you suggest where I would locate such a bulletin if it exists here in the U.S.?
Old Jun 16, 2022 | 10:20 AM
Grouch's Avatar
Thanks,
I would pull the rear wheels and calipers and do a visual inspection to make sure the pads are good. You may not notice an issue with the service brakes but the electric servos might be out of phase. If they look okay, try going into maintenance mode with the brakes and then out of it. There are videos on Youtube that will show you how to do it. You have to follow the procedure exactly to do it, but it is doable. It took me three tries to do it the first time.
Old Jun 16, 2022 | 10:24 AM
Dpthom's Avatar
Thanks so much. This looks like it is above my limited pay grade unfortunately! I'll take to Pep Boys for an inspection.
Cheers,
Old Jun 16, 2022 | 06:12 PM
Grouch's Avatar
Cheers,
It never hurts to go to a shop if you aren't comfortable doing your own work. I'm not a fan of Pep Boys but that's because I know the local store. Folks have had issues there. Other stores may be much better.
I'm curious how you managed to accidentally engage the brake. I did it once on purpose just to see how it acted, but it released okay and didn't make any difference in future operation.
Old Jun 17, 2022 | 01:57 PM
Dpthom's Avatar
I was driving with a cleaning cloth in my right hand and was absentmindedly wiping the center console and pulled on the brake. What an idiot.
Old Jun 17, 2022 | 04:47 PM
Grouch's Avatar
I thought the brake pedal needed to be depressed to engage the parking brake. As for the cloth, I can see that happening. I've seen worse things done. I was driving on ice once and was slipping the transmission into N to keep the rear wheels from causing the Jeep to plow the front wheels when braking. I moved it too far once and put it into reverse at 50 mph. At least the ice didn't lock the wheels.It didn't seem to hurt it though.
Old Jun 17, 2022 | 05:03 PM
Dpthom's Avatar
I don't know much about cars but I believe the footbrake only has to be depressed to disengage the EPB....I was engaging it at the time.
tonto26
Dec 6, 2023 12:22 PM
TSBrewster
Feb 7, 2023 01:49 PM
bobnrobinb
Feb 13, 2022 03:57 PM
glaser67
Dec 28, 2021 08:26 PM
dbockcac
May 21, 2007 12:05 PM
