-   Mazda5 (https://www.mazdaforum.com/forum/mazda5-43/)
-   -   2008 Mazda 5 front shock knocking (https://www.mazdaforum.com/forum/mazda5-43/2008-mazda-5-front-shock-knocking-26294/)
purebeach77 Apr 9, 2011 10:20 AM
My 2008 Mazda 5 has around 36k miles on it and yesterday I noticed that the driver's side front shock makes a harsh knocking sound when I go over a speed bump. Is this a common problem and will the dealership fix it under warranty??
lnwlf Apr 9, 2011 10:52 AM
the fronts are struts and struts will make noise when they are going bad. consult owners manual for warranty info. not sure if it will be covered as it is a wearable item. always replace shocks or struts in pairs.
purebeach77 Apr 10, 2011 05:45 PM
thanks! at least now I can explain it to the dealership. I found replacement ones online for $107 so they can't gouge me.
lnwlf Apr 11, 2011 08:47 AM
have the mounts checked as well just to be safe. if the mount is broken it will be under warranty
kkvasager May 2, 2011 11:32 PM
My 2006 has done this same thing since I got it brand new. It only does it when it's cold out. I did some research back then and found that a lot of people were experiencing the same thing.
ssdspec May 9, 2011 08:54 PM
Check the struts and if not then check the sway bar bushings. I had mine replace for 40 bucks. I did have a blown strut at 50K though. Mine kept making a clanking noise when going over speed bumps and uneven roads.
