2007 mazda 5 overheating while stopped
OK so i recently bought the 07 Mazda 5 grand touring micro van 2.3l 4 cyl and notice that after i have brought the engine up to temp it overheats when not moving. i replaced the engine temp sensor and the fan control module but still doing it. I was recently told that i may have bubbles in the engine so i bled the system. I noticed while bleeding it after about 10-15 mins of idle the radiator would boil over with the funnel in it and almost full.
I know that the previous owner replaced the front end including the radiator and the fan. I have only seen the fan come on a couple times and it never seems to come on when it should which is why i replaced the fan control module. There is no check engine light on it and the only code i pulled from it was the engine temp code which is why i replaced the temp sensor. The only other issue i found is that they put an after market dvd system in the back and i guess they had wiring issues. I know it doesn't have constant power to the inside of the vehicle because they wired in a relay and bypassed the room fuse. That is my next project to correct the wiring, it sucks having to reset the radio every time. Any thoughts on the cooling system? |
im in same boat but mines a mz 5 2.0 rd 2006.
ive replaced thormastat and coolant sensor also checked fuses my last option is to change fan control unit. A/C works and fan works when its on but doesn't kick in when engine gets hot i have to put a/c on when driving to keep it cool. |
Mine didn't work with AC on. I bypassed the fan controller and wired the fan directly. Works but fan is always on.
