Yellow top battery?
Old Jun 30, 2011 | 11:31 AM
icspots's Avatar
Originally Posted by Tracker
Agreed
Sellout, you agreed with me disagreeing with you. :P
So the take home from this OP. If you have a new battery that's working fine keep it as long as it's working fine. If you're building a little system see how it does with everything stock. If you get a little dimming just at peak output look into a capacitor. If your battery starts to go replace it with a better maintenance free battery, but no need to go for a crazy expensive battery for a regular system. If you're putting in something really powerful look into a HO alternator to run everything.
Old Jun 30, 2011 | 02:46 PM
ghostmazda3's Avatar
im not getting any dimming at all. so far i have 4 b&c speakers and 4 rockford tweeters installed with an amp . i just got a 15" subwoofer and when i get the 1200 watt amp for it i will install it. so i was thinkin when i get the sub installed then i would prob get dimming. so thats why i thought i might need to get a different battery. i didnt kno yellow tops had issues. so is it safest to just get a better battery than stock? the car is about 3 months old so the battery is new. just worried about dimming once i put in the sub woofer and the amp . thanx for all your info by the way
Old Jun 30, 2011 | 03:43 PM
I'm sure much of that will depend on just how much you crank it up!
Yes, In my opinion, those batteries are a scam because they look cool but don't produce.
The owner/ADMIN on my other Mazda forum lives in Japan and has a 3 rotor Enos. He had a red top in it until recently and had nothing but trouble with it. Said he has done much better with a Mazda factory replacement battery.
Take our advice and spend your money wisely. You could easily buy two high quality batteries for what the red/yellow tops cost, and be much better off for it.
Old Jun 30, 2011 | 05:51 PM
icspots's Avatar
I would definitely just wait and see what happens. If you get dimming then turn down the sub a little to reduce it until you can get a better battery or install a capacitor. Also make sure to occasionally check the water level in the battery. Like I said above (or on another page.... whatever) they're not the best batteries but it's not worth just chucking it while it's still working fine.
Old Jul 2, 2011 | 11:01 PM
Tracker's Avatar
I only agreed because i was starting to think i was "overthinking" the situation, besides your kinda like the resident aftermarket accessories expert on here :P.
Old Jul 5, 2011 | 10:05 AM
thanx everybody. i will post the details when i get the sub installed. hopefully this week it will happen. im gonna see what happens with the stock battery .
Old Jul 12, 2011 | 10:40 AM
ok i couldnt take it anymore just to be safe i got a kinetik 800 battery for the trunk. so def wont have any probs now. getting a custom box built for the sub this week since already made boxes cant even fit in the trunk (-___-). so i have an audio pipe 2500 amp for the sub . cant wait. thanx again everybody.
Zevy3
May 7, 2010 06:35 PM
M3 For Second Time
Jan 5, 2009 05:24 PM
Yellow_RX7
Sep 1, 2007 06:48 AM
MAZDA MAN
Aug 15, 2005 05:57 PM
CharlieFoxtrot
Apr 20, 2005 02:51 PM
