What the Mazdaspeed 3 has to offer
Infromation was taken off of streetunit.com posted up by StreetUnitMike. I'm taking no credit for this. Just posting it for information. How about a sticky, mods?
2007 Mazdaspeed 3 - Specs Vehicle type: front-engine, front-wheel-drive, 5-passenger, 5-door wagon Major standard accessories: power windows and locks, remote locking, A/C, cruise control, tilting and telescoping steering wheel, rear defroster and wiper Sound system: Mazda AM-FM radio/CD changer, 6 speakers ENGINE Type: turbocharged and intercooled inline-4, aluminum block and head Bore x stroke: 3.44 x 3.70 in, 87.5 x 94.0mm Displacement: 138 cu in, 2261cc Compression ratio: 9.5:1 Fuel-delivery system: direct injection Turbocharger: Hitachi-Warner K04 Maximum boost pressure: 15.6 psi Valve gear: chain-driven double overhead cams, 4 valves per cylinder, variable intake-valve timing Power (SAE net): 263 bhp @ 5500 rpm Torque (SAE net): 280 lb-ft @ 3000 rpm Redline: 6700 rpm DRIVETRAIN Transmission: 6-speed manual Final-drive ratio: gears 1–4, 3.94:1; gears 5–6, 3.35:1; limited slip Gear: Ratio: Mph/1000 rpm : Speed in gears I : 3.54 : 5.3 : 36 mph (6700 rpm) II : 2.24 : 8.4 : 56 mph (6700 rpm) III : 1.54 : 12.2: 82 mph (6700 rpm) IV : 1.17 : 16.0 : 107 mph (6700 rpm) V : 1.09 : 20.4 : 136 mph (6700 rpm) VI : 0.85 : 25.9 : 155 mph (6000 rpm) DIMENSIONS Wheelbase: 103.9 in Track, front/rear: 60.4/60.0 in Length/width/height: 176.8/69.5/57.7 in Ground clearance: 4.8 in Drag area, Cd (0.32) x frontal area (25.5 sq ft, est): 8.2 sq ft Curb weight: 3180 lb Weight distribution, F/R: 63.5/36.5% Curb weight per horsepower: 12.1 lb Fuel capacity: 14.5 gal CHASSIS/BODY Type: unit construction with a rubber-isolated crossmember Body material: welded steel stampings INTERIOR SAE volume, front seat: 51 cu ft rear seat: 44 cu ft cargo, seats up/down: 17/43 cu ft Front-seat adjustments: fore-and-aft, seatback angle; driver only: rear height, lumbar support Restraint systems, front: manual 3-point belts; driver and passenger front, side, and curtain airbags rear: manual 3-point belts, curtain airbags SUSPENSION Front: ind, strut located by a control arm, coil springs, anti-roll bar Rear: ind; 1 trailing arm, 2 lateral links, and 1 toe-control link per side; coil springs; anti-roll bar STEERING Type: rack-and-pinion with electrohydraulic power assist Steering ratio: 14.7:1 Turns lock-to-lock: 2.7 Turning circle curb-to-curb: 36.1 ft BRAKES Type: hydraulic with vacuum power assist and anti-lock control Front: 12.6 x 1.0-in vented disc Rear: 11.0 x 0.4-in disc WHEELS AND TIRES Wheel size/type: 7.0 x 18 in/cast aluminum Tires: Bridgestone Potenza RE050A, 215/45R-18 93Y Test inflation pressures, F/R: 33/32 psi Spare: high-pressure compact on steel wheel Car and Driver TEST RESULTS ACCELERATION (Seconds) Zero to 30 mph (2.3) 40 mph (3.4) 50 mph (4.4) 60 mph (5.8) 70 mph (7.2) 80 mph (9.3) 90 mph (11.4) 100 mph (14.8) 110 mph (17.8) 120 mph (21.9) Street start, 5-60 mph: (6.7) Top-gear acceleration, 30-50 mph: (10.6) 50-70 mph: (6.8) Standing 1/4 mile: 14.4 sec@ 99 mph Top speed (drag limited): 155 mph BRAKING 70-0 mph @ impending lockup: 167 ft HANDLING Roadholding, 200-ft-dia skidpad: 0.87 g Understeer: minimal moderate excessive FUEL ECONOMY EPA city driving: 20 mpg EPA highway driving: 28 mpg C/D observed: 18 mpg INTERIOR SOUND LEVEL Idle: 47 dBA Full-throttle acceleration: 78 dBA 70-mph cruising: 75 dBA[/align] |
RE: What the Mazdaspeed 3 has to offer
^ That's kinda shamless....
Enjoy the information.
oh how i wish i had held out on buying a car! i would kill for a speed.
sigh. guess i'll have to wait until i get another 20,000+ to blow on a car right? lol [&o] Stephanie |
lol trade ur car in.. definitely worth it :-).. i bet ud give up drinking jsut for the car!! lol
Hey how much did it cost to get that sunroof installed and does it make the body less stable or anything like that? why didnt they put one in from the factory? and how easy is it to install those new HID's?
thanks Brennan |
sunroof will make it much cooler
ORIGINAL: fb4life5002 Hey how much did it cost to get that sunroof installed and does it make the body less stable or anything like that? why didnt they put one in from the factory? and how easy is it to install those new HID's? thanks Brennan |
the numbers for mileage were on the old EPA standards. it is now 18c/26h.
have any of this info for the reglar 2.3L?
