Tell me about my new '08 Mazda 3 s GT
Hey all, I'm new to this forum and the Mazda world. Just picked up an '08 3s GT last night with 30k miles on it. I'm wondering if you guys can give me the skinny on it (other than the stuff in the manual and published specs, etc). I already know that it drives awesome, of course ;) I'm most curious about how often you'd recommend full-synthetic oil changes and any performance-boosting aftermarket parts, as well as reasonably-priced all-season tires that will last the longest given the negative camber. Any additional "insider info" is also welcome.
Cheers! -Russ |
Originally Posted by variableresults
(Post 125457)
Cheers! -Russ
I run Mobil 1 10W-20 at 4-5k, seems to do alright.
As for tires, I have found a set of Riken Raptors that are doing extremely well, good ride, good traction in snow. They are sitting at 36k with 50% tread left. |
Originally Posted by apbbnbanb_07
(Post 125459)
I change my oil out every 5k or so, sometimes it goes a little longer depending on weather/schedule/motivation. If you want to do the real way to check it then do your oil change and at the next change send a sample off to blackstone labs to have it analyzed.
Incidentally I use 5w20 mobil one full synthetic. |
You can run regular oil 4-5k. Synthetic should last 10k.
I'm not an oil expert, but I would stick with the 5-20 range since that's the recommended weight. If you can find a 0-20, that may be fine, as it would make your winter starts even easier- -but I would stay away from any higher weights on the low end. My 2 cents.
Not sure about Mazdas, but with some other cars that have been running dino oil for a long time, switching to a thinner synthetic will sometimes bring out leaks- - perhaps long time owners can comment on that. |
I've always run synthetic in mine and change the oil at 6-7k intervals.
Stock Goodyear's = bad Kumho Ecsta = better Yoko's = even better |
