Sway/anti-roll bars for the 3 BL
Hey guys,
So upgrading my 2011 2.0L's suspension to coilovers cause i blew a needed to replace 2 struts and mazda quoted me 1200Au for parts, so i got some BC racing BR's for 1500 and figured while im there i should put new sway bars in Any recommendations? Im looking at racing beats But i was hoping for tubular but cant find any for the 2.0 i know i need new links at the same time |
FYI. There is no performance difference between a tubular and a solid bar. This is simply the choice of the manufacture and the engineer that designed the specif anti- roll bar.
This is where many get confused with sizing because of the two types which can not be used for comparing specifications of performance based on O.D. I would recommend that you talk directly with the manufactures or authorized dealers of the anti-roll bars you are considering. You will need to tell them your intended driving use and all your suspension upgrades along with the tires you use. |
Whiteline have a good reputation for sway bars.
