Side mirror replacement
Hello. I own a 2010 Mazda3s. Today I was sideswiped and my mirror on the passenger side completely broken. I am looking to buy an inexpensive replacement that I can install myself. The part number is BBM4 69 120. However, I cannot find any part that matches that number. I do see BBM4 69 12ZN that says it will fit a 2010 Mazda3 unheated w signal- which is what I need. Would this be compatible with my car? Many thanks!
STOP! Don't buy this from the dealer unless you have to. First try www.rockauto.com then at least try your local salvage yard. The mirror is super-easy to replace, you can do it yourself.
Rock Auto has them for under $60.
RGAZ
RGAZ
I am not sure what your question is. IF you want to see if Rock Auto has it, go to their website and filter down to your specific car. Then choose the item you want. You don't need the part number. Also, if you find the right item you can click INFO and it will give you the aftermarket part number if you want to try and cross-reference it.
Does that help?
Does that help?
