side marker light replacement
Has anyone tried replacing the side marker bulbs? I know it says they come with a kit. But, there has got to be a way to switch them out with some hyper whites! Puhleeeeeeeeeeease! let me know
RE: side marker light replacement
what is in this "kit"..
and hyper whites are headlights...do you mean like a blue or clear side marker? |
They're a turn signal repeater and they are replaced as a unit. You might break intoone, but you take the chance of destroying it, and they cost upwards of $40 ea. from what I've seen. Seems kinda' silly that Mazda would design them that way whena 194 bulb cost, what 20c, but watRUgonnado? |
ORIGINAL: virgin1 They're a turn signal repeater and they are replaced as a unit. You might break intoone, but you take the chance of destroying it, and they cost upwards of $40 ea. from what I've seen. Seems kinda' silly that Mazda would design them that way whena 194 bulb cost, what 20c, but watRUgonnado? |
Ooops!This came up in the "new posts today" and I never thought to look at the dates. Why did it do that? |
Forums Ghosts :D
Old thread not-withstanding.....
The OEM ones are a single unit replacement, and I believe they cost about $14 each. You can cut them open carefully with a dremel to change out the bulb and then silicone them back together. I think ........ streetunit?...... or someone sells clear LED models but they tend to be a little pricey. |
im reviving threads today hahaha lol.
ORIGINAL: icspots Old thread not-withstanding..... The OEM ones are a single unit replacement, and I believe they cost about $14 each. You can cut them open carefully with a dremel to change out the bulb and then silicone them back together. I think ........ streetunit?...... or someone sells clear LED models but they tend to be a little pricey. As for the LED versions, I've seen them on eBay too, and the price isn't that bad, but not my taste. I'm wantin' to get rid of the things altogether and smooth out that fender bulge. |
| All times are GMT -5. The time now is 05:15 AM. |
