Removal of Cold Air Intake Filter
Old 12-02-2007, 08:20 PM
Drift3s's Avatar
Default Removal of Cold Air Intake Filter
I'm looking at installing a cold air intake which I know requires taking the left front wheel off and part of the splash gaurd to remove the stock air box.I also noticed thatthe aftermarket cold air intake filteris positioned down near the wheel well when installed. Does anyone know ifI need to go through this same process when removing theair filter for cleaningor can it be reached without removing the wheel and splash guard? This will utlimately help me decide whether to go with the short ram or full cold air intake.
Old 12-02-2007, 09:13 PM
dentinger's Avatar
Default RE: Removal of Cold Air Intake Filter
you can take the bumper off.
trust me, its WAY easier.
11 screws along the underside of the bumper, 1 screw on each side of the bumper(on the inside, where the bumper meets the fender), and 2 screws where you grill is.
its not as hard as it looks. i can take my bumper off in about 10 minutes now.
Old 12-02-2007, 09:24 PM
Drift3s's Avatar
Do you put the front end on jack stands or do you just crawl under and unscrew the bumper? Let me get this right. You have to take off the front bumper everytime you want to get to the air filter?
Old 12-03-2007, 04:05 AM
No. But like the man said, it's easier that way.And, you'll get more from aCAI than anSRI.
Old 12-03-2007, 07:18 AM
I put the K&N short ram intake on my mazda3 recently but i havent had to clean it yet.
you could potentially take the short ram intake out from the top, just remove the intake from the throttle body. Do you know how often you should clean your intake???
Old 12-03-2007, 07:19 AM
also how much more will you get out of CAI than SRI?
Old 12-03-2007, 01:54 PM
MS recommends 20K for my CAI between cleanings, but an SRI lives in the engine compartment so it may be more often. I'm not sure about that one though.
According to the dyno sheets I've seen, usually 2-3hp, but w/o any other mods (i.e. header and/or exhaust system) the gain would be reduced anyway. If the engine can't exhale, it can't inhale as much either.
DjSlickSVG
01-27-2014 11:29 PM
zakkzander
Intake, Headers and Exhaust
06-24-2013 12:58 PM
linuxguy0481
04-14-2012 05:25 PM
knucklehead11
06-15-2010 06:51 PM
mazda guy
03-11-2007 05:00 AM
Quick Reply: Removal of Cold Air Intake Filter
