Shocks for Eibachs
I'm looking at getting a set of Eibach Proline springs for my car. What shocks match up to those springs?
I can only comment about the research I have done since I ended up using stock struts for the time I had springs, but everything I have read those koni yellows are great for lowering springs and they are adjustable.
well if your not looking to adjust your height then id just go with mazdaspeed ones
The Eibach ProKit springs with regular Speed3 stock shocks? The ProKit does lower it but I won't be doing any more than that.
I have yellows on w/H&R springs and it's definately stiffer/harder riding than before. The rears are set about half way and the fronts are set completely loose. The OE's will do fine, but may wear a little faster since they won't be quite centered any more, but I have not heard/read of any real problems using the OE's. If you want the complete package, I suggest looking into the Koni FSD system. Comes complete as a kit. The shocks are not manually adjustable as they are using the yellows but are designed to self-adjust based on conditions. They are said to ride well over normal roads but the valving stiffens them under more extreme conditions. The entire kit is around +/- $600, which isn't bad. |
no i wasent talking about the stock ones off the speed 3, i was talking about the ones sold by the performance division. MAZDASPEED - Accessories - Mazda USA
It doesn't look like the Koni FSD is available for my car unless that's what they call the STR.T in their finder.
I wonder who makes the Speed sport dampers. |
Oops. $740 w/matching springs (Eibach ProKit, just what you were looking for... 1.4"F/1.2"R) but you may be able to do a little better shopping around. Koni FSD Damper Set & Springs |
mazda makes the mazdaspeed parts
Ummmm, you sure about that, Tracker? I know Eibach originally made (makes?) the MS sway bars, and that AEM produces the CAI for MS. I would imagine the sport shocks and coilovers are also produced by a company that already has that capability, albeit to Mazda's specifications... which may, or may not be the same as the AM parts being produced from the same jobber/vendor. In either case, I think the Koni FSD is the better buy all around. A complete package for $740. The MS shocks/struts alone are $560. Add another $200+ for the Eibachs and your still saving a few bucks. Easier to get, I'd bet too. |
