Road Noise on 18 inch wheels?
Old Mar 31, 2018 | 06:44 PM
MichiganMike's Avatar
Originally Posted by shipo
Hmmm, our Mazda3 with 18" wheels isn't home right now, but I'm pretty sure it came with Pirelli tires; they're nice and quiet.
The only tire that Tire Rack lists as original equipment for the 2018 Mazda 3 GT with 18" wheels in the US is the Dunlop SP Sport 5000. Are you sure the Pirelli tires were OEM on your Mazda?
https://www.tirerack.com/tires/TireS...inLoadRating=S
Old Oct 26, 2023 | 08:59 PM
M3newbee's Avatar
Default noise
Originally Posted by eramitgoyal
Hi All,
I have booked a Mazda 3 2018 SP25 variant. It comes with 18 inch alloy wheels which look good but have thin tyre profile. Does it mean they will produce annoying road noise? How bad it can get? I am surprised to see that this topic is not discussed much here in the forum. Does it mean the problem is not that big?
Thanks,
Amit
My 2016 Mazda3 GT that I just purchased came with 18inch Dunlop 5000 that are starting to show the wear indicators, but I’m told have another season left, are the noisiest tires I have ever heard. I know uneven wear and reduced tread adds to road noise. Even the winters on steel rims are not that noisy, although not quiet either. My dunlops registered 78decibles while the winters were a high of 74db. That small difference makes a lot of difference in comfort level. I have been researching tires and find there is conflicting info available on road noise. For example: Michelin x climate 2 is rated the most quiet on some sites and “loud” on other consumer sites. Also it doesn’t have the tread characteristics cited in the description of quiet tires. I did learn that higher sidewall and smaller uniform tread design improves things. Also a new tire after being broken in, will usually be better, but deteriorate with time and wear. I’m not sure if there are any stats on longevity of quiet comfort in tires. That would be very helpful. Let me know if you find any reliable info as I’m very interested in this subject too, as I have tinnitus and am more sensitive to road noise.
Cheers
m3newbee
Old Oct 27, 2023 | 12:23 PM
Cheers
m3newbee
Welcome to the forum.
You posted on a rather old thread? Last posted was on 03-31-2018 03:44 PM
I am curious what you used to measure the db.
I do have a couple of hand held db for use in audio sound both vehicle and home as well diagnosing engine sounds and noises.
Most of your info is spot on.
I doubt there will any information that is credible about increased tire noise level with age or miles because this varies so greatly by to many input factors.
Old Oct 28, 2023 | 05:41 PM
M3newbee's Avatar
Hi Callisto. Thanks for your reply. I just used an app called “Sound Meter”. I don’t imagine it is perfectly accurate, but I thought it would give me a relative idea of the noise levels. cheers m3newbee
Old Oct 28, 2023 | 05:54 PM
M3newbee's Avatar
Default weather door seals for noise reduction
Has anyone used door, trunk and hood rubber weather stripping from eBay? It is peel and stick and is supposed to help with noise levels in the cabin. I haven’t installed the seals yet as I’d like to see if anyone else has tried it and if it was helpful. It is supposed to be specific to M3.
Thanks
m3newbee
This is the installed seals. Instructions are non existent
Old Oct 28, 2023 | 07:56 PM
To be clear and simple...They will do almost nothing, and it can be accurately measured. as doing nothing using a db meter. It is more selling advertising hyp on most vehicles from about 2000 and newer and most all Mazda from 2014 to present.
Actually IMHO likely no vehicle that has at least the factory weather stripping ...
To reduce more sound in the interior requires a lot more work and that would be applying sound reducing material like FAT MAT.
Old Oct 28, 2023 | 08:04 PM
M3newbee the road and other noise is caused from MAZDA using more sound proofing material. almost nothing on the body none in the head liner or wheel wells to speak of and bare minimum on the floor.
My guess having done most all those the biggest 2 areas was #1 the floor, that is the complete area and hatch or truck under the carpet. The second biggest noise area is the roof or complete area between the headliner and roof. Then the body doors. Moving on to the wheel wells and then the last the complete undercarriage. The investment to have an Audio shop do this is about 3k. Well worth the investment.
Trust me when I say doing partial area's only addicts you to want to do more because of the drastic decrease on outside noise influences.
Old Nov 24, 2023 | 02:59 PM
M3newbee's Avatar
Just to be clear, the size of the wheels has very little to do with road noise, that said, tire design and tread patterns have a lot to do with it. As a general rule as long as the sidewall height is at least 4", there should be no difference in noise when compared to a tire with say 5" if sidewall height; as you start getting thinner than 4", yes, there can be an increase.
FWIW, we have a 2016 Mazda3 s GT with the 18" wheels wrapped in 215/45 R18 tires and there is virtually zero road noise.
What tires do you have on the 2016mazda 3GT with 215r45 18inch rims?. That is the car I just bought and the sport dunlops are horrible for noise and need replacing. The winter tires are Winterclaw 215r45 on 17 inch steel rims. They have a lot of life left, but are quit noisy. I have to drive with ear plugs. I want to at least replace the dunlops but I want to get the best tire for a quiet ride. I don’t care about fuel efficiency, or performance that much. Any help you could provided would help. Sorry I know this is an old post, but hope you might be able to reply.
Old Nov 25, 2023 | 10:49 AM
Shippo has been gone form responding on this forum for a long long time. Last Activity: 01-17-2021 08:37 AM
However I will contact him and see if he wants to respond?
Old Nov 25, 2023 | 09:55 PM
shipo's Avatar
Per a post above from five years ago, our 2016 Mazda3 s Grand Touring 5-Door came with 18" Pirelli tires, however, I don't remember which model as they are long gone. Our car is now on its third set of rubber, set two was some flavor of General G-MAX all season tires and the third set is the 215/45ZR-18 General G-MAX AS-05 model. Since the Pirelli tires which came OEM on our car were noisy and quite "done" looking after only about 35,000 miles, I switched to the Generals and they nice and solid for 45,000+ miles, so now we're on the second set of Generals.
sigsvet61
Jul 9, 2022 07:19 AM
Kjaerlarsen
Nov 27, 2020 06:28 PM
Charlesviiii
Apr 7, 2019 07:28 PM
alaswa
Aug 5, 2005 05:17 AM
nittany
May 26, 2005 12:51 PM
