Reverse Light
How can I make my one reverse light brighter? Is there a brighter bulb that wont melt the housing? Its not really all that bright when its very dark out, even worse when its raining.
I have actually replaced mine with LEDs, they are much brighter and shine a nice natural light in the rear of my car.
It also helps that they are low power consumption and produce little to no heat. |
Do you have part numbers by chance??? :D :D
I've had the same problem, and looking at LED lights, their specifications look a lot dimmer than the stock lamps. This is something i've got slated for a summer project. Let us know if you install LED lamps or find some other solution.
I was thinking of installing a set of fog lamps and point them rearward - tie that to turn on with the reverse lights. |
