Remote Starter Problem
Im having trouble with my remote starter that i bought from Mazda on my 2010 sport hatch.
The car starts fine but once i try to get in the car and open the door the engine shuts off I tried opening the door with the key but it doesn't work and the engine still shuts off. Any other suggestions. Thanks |
Originally Posted by kingmansnyper
(Post 103900)
The car starts fine but once i try to get in the car and open the door the engine shuts off I tried opening the door with the key but it doesn't work and the engine still shuts off. Any other suggestions. Thanks Another thing that would disable the running engine was when I pushed in the brake pedal without having inserted the key and turning it to the running position. Course, opening the car wouldn't normally disable the running engine unless the alarm was armed with the door unlocked. Usually it would lock all doors automatically when I armed it but there were oddball times that it wasn't. |
not much car knowledge
i've never actually been too knowledgable about cars or the few mazda's i've had. i know dealer garages can rip you off but my local garage sgh has never done me wrong www.sghbodyworks.co.uk but i guess this is only useful if you're in the uk.
Hi, So i reread some of the manuals and the remote start is made to turn off when the door is opened and there is nothing i can do about it, i plan on upgrading the remote start with a viper system, but i don't know if a new system will upgrade the old and the door mechanism will change.
Be careful when buying a remote starter on your 3 when you don't have the GT trim. Just get an aftermarket system. i will post again to see if the viper system has the same problem or if the safety feature is on all remote starter systems an suggestions on how much an aftermarket switch should cost? |
