Puzzling battery drain
I have a 2013 Mazda3 Hatchback with 70k miles. I just replaced the battery. If it’s not run for four days it won’t start.
I disconnected the negative battery terminal and put a current meter between the battery and the lead and am measuring a 1.5A current with the car off. I pulled every fuse, one at a time and measured current as above. Removing the #46 fuse dropped the leakage current to 1.2A. Removing any other fuse did nothing (still had 1.5A leakage). I’m presuming the .3A on the #46 fuse is normal and that I have a 1.2A unfused (at least in the fuse box) leakage. I noticed there appears to be a fuse on the positive battery terminal. Anybody know what loads are infused in the fuse box (or have a manual with a complete wiring diagram)? Perhaps the starter? Alternator? Other ideas of what might be going on? Other information, possibly unrelated: we recently had the water pump replaced. After that work the Bluetooth functionality no longer works and I can’t get it into the Bluetooth setup routine. |
I had a similar problem on my 2010 Mazda 3. Ended up replacing the Bluetooth Module which I purchased on ebay and the battery drain problem went away.
@ronb amazing thanks for the info. I guess I’ll go ahead and replace the Bluetooth module.
Out of curiosity, did you also check leakage current while pulling fuses and find no fuse that eliminated the leakage current?
Originally Posted by ronb
(Post 199744)
I did detect current drain. I don't remember if I found a particular fuse that stopped it because I ended up replacing the Bluetooth module while I was troubleshooting it and it was almost two years ago.
