Power Steering Pipes
Hi all,
My partner has a Mazda 3 2007 2.0l TD Sport. Power steering pipes are leaking. Ive tried all the scrap yards no one has any. My question is, is any other vehicle got the same pipes? The Mazda 6 GG 2.0l diesel looks to have the same engine will their pipes fit. Im at a loss. Any help would be appreciated. Ive fixed them once already but with the rust I really need good working set. |
Is the steel pipes that are leaking or the black flexible hoses?
Metal, but right at joint to flex, as the run along wheel well.
Ive covered a previous leak by patching but really need to replace them as they are really in a bad way |
Have you enquired with hydraulic hose companies to make up new hoses?
What about a steering repair shop/ overhaul shop? Have you priced a set from Mazda? |
Your local NAPA store may be able to make the hose for you. You would need to bring it in for them to duplicate. If not NAPA, then do a local search for "hydraulic hose" repair. You may get a Caterpillar or Farm Equipment place.
RGAZ |
