pls help. what do i need
just go the Mazda 3 gt sedan. i want to drop a turbo on it down the road. aside from air intakes, headers, exhaust. what else do i need to modify or replace so i wont have any engine problems? do i replace the cam shaft. fuel injectors, pulley gears, where can find the mod chip for it. i would appreciate it alot. i just want it to be smooth and no big problmes blowing my engine. im not planning to put a NOS on it just a turbo. thanx
RE: pls help. what do i need
Did you get a good deal on the base 3? I would have just pulled money together for the stock turbo'd speed 3.
yeah, but the stock speed3 (only) make 263 horsepower.
if you use turbo setup from HiBoost, along with forged rods, you close todouble that of the speed3. thats what im planning on doing when my lease is over (and i buy my mazda out of course) |
But you would just start at 263 hp with the Speed3...you also get a better transmission with 6-speeds and Limited slip diff, you get wider fenders to clear wider tires, you get a stiffer chassis through unique to the Speed3 bracing in the unibody, you get 10mm lower suspension & increased rate sway bars....It's more than just a turbo.
I agree, the base Speed3 is a steal. Just to add a turbo you're probably looking at $3-4K additional, it you got your Base 3 for 18K, you're already pushing Speed3 prices without all of the extras listed above.... |
DON'T FORGET THE SUPERIOR BRAKING OF THE MS3. YOU WILL NEED IT.
Also, the crankshaft and connecting rods are forged from the factory with the Speed3...so there is plenty of room for more power (the blocks have been proven to be strong enough for massive power)
true....i never thought about all the extras
how much power do you think the speed3 can make?? (with aftermarket turbo's and whatnot) |
Just as much as any other turbo system....For real big power you'll end up changing out for a larger turbo, freer flowing exhaust, etc,etc....Bottom line is Mazda does a ton of stuff for you and you have a warranty for 50,000 miles.
dont forget about that cai exhaust package putting a 35 hp increase and 30 pds torque increase
Speed costs money son....how fast do you want to go??? The only limit is your wallet.
| All times are GMT -5. The time now is 02:44 AM. |
