-   Mazda3 (https://www.mazdaforum.com/forum/mazda3-26/)
-   -   A-Pillar (https://www.mazdaforum.com/forum/mazda3-26/pillar-26027/)
mzdaspd304 Mar 7, 2011 05:48 PM
A-Pillar
How do you remove the A-pillar? Any special tricks?
icspots Mar 8, 2011 05:17 AM
open door
grab rubber door trim along front edge of door frame and pull away from the frame
grab pillar and pull towards inside of car to release two tension clips (towards the bottom and in the middle)
slide the pillar towards the roof to release from the white pop clip at the top.
Viola
Aubrey Mar 9, 2011 10:11 AM
Uh... do you have airbags in them there A-pillars?
icspots Mar 9, 2011 01:31 PM
I do. the airbags are attached to the actual pillar of the car, not the plastic trim piece on the inside. You won't be able to activate the airbag by removing the trim. If you are concerned by it then you can always disconnect the battery, and step on the brake for a minute to drain the capacitors.
