New rims and TPMS
If I were to purchase new rims, will the sensors from my stock rims work with most AM rims, or do I have to pay the $180 theyre gonna charge me?
I'm not an expert, but I think and have heard that the TPMS sensors can be moved to new wheels. That may depend on a number of factors, such as where they could, or if they could be mounted inside the new wheel. I think the OE sensors could be used? Ask them to show you why they couldn't. |
Originally Posted by apbbnbanb_07
(Post 103388)
also you cannot get rims that are not over or undersized make sure you get the right size
Originally Posted by Tracker
(Post 103413)
also you cannot get rims that are over or undersized. make sure you get the right size
Please explain? Do you mean: A new size (larger or smaller in diameter) would affect the stationary sensor location and therefore would have to be moved either inward or outward of the OE mounting point to compensate? Is it possible that different sensor locations are built in from the factory to accommodate 16", 17" or 18" wheels? |
I planned on it, I would like to keep the tires I have now seeing as they are fairly new, and I would rather have the stock size anyway.
sorry what i ment was getting a size bigger or smaller than what is offered from oem, going below 16in may cause problems as well as going bigger than 18.
Originally Posted by vlstellato
(Post 103402)
You shouldn't have a problem, a friend of mine who is a service tech for a local garage said when the change out stock wheels to AM they do one at a time so the TMPS doesn't go in to fault mode. The only thing thats sucks is that you have to pay extra to remove the sensors from the stock wheels
I think it's safe to say they were trying to hose you. I live in a town of less than 2000 people and I had my tires put on at a rinky dink farm tire shop.
No problem with the sensors, though they tend to break them occasionally the shop should pay for it. |
