-   Mazda3 (https://www.mazdaforum.com/forum/mazda3-26/)
-   -   Need help with squealing (https://www.mazdaforum.com/forum/mazda3-26/need-help-squealing-28643/)
sttatik Feb 20, 2012 01:07 PM
hello..
i have a 2006 mazda 3 2.3 hatch... everytime i shift gears i get a quick squealing noise... no idea if its just the dbelt or any other possible issue... its not the brakes nor the suspension..
any clue?
thank you
virgin1 Feb 20, 2012 02:37 PM
It could be the clutch throwout bearing taking a dump?
It could also be the clutch disk center coming apart. e.g. Perhaps a take-up spring is loose, or has rotated?
But you don't really say at what point during the shift you hear the noise.
sttatik Feb 21, 2012 08:36 AM
i appreciate your quick response.. i do think i need to rephrase a couple things..
the squealing / chirp does happen occasionally when shifting through the gear as i accelerate... once in gear just maintaining a constant speed the chirp would happen again.. this happens at random speeds...
the quick chirp sounds like its coming from the right front tire or possibly the engine bay.. its just impossible for me spot while driving.
i wasnt sure if anyone would know the cause.
thanks again
icspots Feb 21, 2012 01:49 PM
It's possible it's one of the belts as well. It could be if you're turning or accelerating while driving that the engine is shifting on it's mounts as it torques and the belts are squeaking somewhat. See if you can get it to reproduce at will by reving.
tanprotege Feb 21, 2012 04:52 PM
Somewhere else a guy had an issue with a chirp and found that a nut on a suspension control arm needed tightening. Can you produce the chirp while shaking the car? Open the door and use it for leverage.
Tan
thanks again
sttatik Feb 22, 2012 08:25 AM
i'll try all the tips mentioned and keep you guys updated. thanks!
