-   Mazda3 (https://www.mazdaforum.com/forum/mazda3-26/)
-   -   need computer reset for mazda 3 (https://www.mazdaforum.com/forum/mazda3-26/need-computer-reset-mazda-3-a-24039/)
tanka Sep 3, 2010 09:09 PM
battery change for mazda 3 2005 need computer reset
Tracker Sep 3, 2010 09:18 PM
what? why would you "reset" the computer, i dont really understand what u mean
icspots Sep 4, 2010 10:27 AM
Disconnecting the battery will reset the ECU.
Tracker Sep 4, 2010 08:32 PM
well if he changed the battery then the ecu is already reset, thats why im confused
Kemick10 Sep 8, 2010 05:41 PM
disconnect the positive battery terminal only for 15 min then put it back on... should reset all of your lights but wont take the code out of the ecu
tanka Sep 8, 2010 07:04 PM
changed the battery
i changed the battery and after that sometimes the car when stopped at the lights the engine stops on me i then have to start the car again... does anyone know why this is going on ... does the computer in the car have to be reset or put a code for the battery???
Tracker Sep 8, 2010 09:09 PM
stalling @ idle is something that cant be solved by resetting the ecu, it may require a reflash (dealer only), or it may be a bad maf or anything fuel or ignition related, the info given is very sparse and its gonna end up having to be taken somewhere to get fixed anyway.
tanka Sep 10, 2010 04:46 AM
thankyou
icspots Sep 10, 2010 08:16 AM
Have you gotten any check engine lights?
Like Tracker said this doesn't really sound like a ECU issue and replacing the battery shouldn't cause that issue. That said something that would cause it would generally trip a CEL.
The only similar thing I ever had happen was on my old ranger where the negative terminal wasn't making good contact with the battery post. It would frequently stall when stopped (and by stall I mean the negative terminal would become disconnected and there was no power at all). I'd have to jump out, jiggle the terminal and then start the car. I'd cleaned and tightened it several times but finally had to end up replacing the terminal/cable. Worked great then. :lol:
jesse87 Jun 21, 2011 12:22 AM
i cant change the speedo
