if your canister keeps getting clogged which is preventing the fuel from going in, the only two possible things i can come up with is that the gas your putty in is REALLY contaminated (its possible) or the material inside the canister is breaking down for some reason and needs to be replaced, really should have a tech look @ that.
It shouldn't be the fuel filter at all. U should bring it back to your dealer to check for the problem.
im having the same issues. i noticed on mine that fuel actually comes back out of the vent tube if I try to force the fuel in. I thought that the vent tube may have been blocked until i saw that. its driving me crazy. could their be a filter of some kind in the filler tube?
im going to check the vent tubes anyway. |
I'm having the same problem with my Mazda Protege. It doesn't matter where I go to buy fuel, the pump clicks off in about 10 second increments. I'm taking it apart today to try and find the problem. Has anyone found a solution?
Originally Posted by Flight370
(Post 112384)
Some other ideas.
http://action.publicbroadcasting.net...t/2148800.page |
Fix
Originally Posted by tec2go
(Post 112399)
Still going with that 10 cents at a time....
Same problem
The same thing started happening with my CX-5 last week. I thought that it might be the nozzle on the pump the first time, but I had the same problem at a different station this morning.
| All times are GMT -5. The time now is 05:57 AM. |
