intake idle/start up problems
I recently installed a cold air intake on my 06 mazda 3. Since the install I have been noticing some problems and was wondering if I can do something to fix them or just let the computer fix its self.
1. when I start the car, unless im revving the engine, the rpms are bouncing slightly and keep going low and sounds like the car is about to die. ( has died a couple times) 2. when i accelerate it seems like the car is accelerating way slower than normal 3. when I'm on the hwy and the car is in fourth and I have to slam on the gas, the car down shifts to 3rd gear or in a few instances all the way down to second. My check engine light came on the other day and when i got the code checked they told me it was an o2 sensor. sorry for the lengthy post. thanks in advance. any help is appreciated greatly. |
You probably have extra air coming in from an unplugged vac line or loose connection. Many times a vac line gets removed from stock air box and not re-used, this must be plugged. Otherwise your intake brand sucks. What brand is your cold air intake.
Double check these instructions: http://www.knfilters.com/instructions/69-6010_inst.pdf |
