help with sub install
Old Jun 10, 2009 | 04:18 PM
ninjaboy's Avatar
Default help with sub install
can someone tell me how to put the amp to the deck? i can hook up the sub from there but idk how to deal with the amp. i know it has something to do with the av cable but i don't know how to access the port on the deck, do i have to remove it?
appreciate the help
Old Jun 10, 2009 | 09:27 PM
apbbnbanb_07's Avatar
Use the search option of the forum, this has been answered many times before.
Old Jun 10, 2009 | 10:31 PM
jaimie08mazda3's Avatar
are you using it through the stock deck or an aftermarket deck?
Old Jun 10, 2009 | 10:52 PM
ninjaboy's Avatar
straight up stock
Old Jun 10, 2009 | 10:58 PM
so basically you are putting a sub or two with the stock head unit am i right? ive done it and many people have done it.. I also wrote a sticky on how to do it. https://www.mazdaforum.com/forum/audio-visual-electronics-10/hooking-up-subwoofer-if-using-stock-deck-17482/ if you have any questions let me know.. ive run 4 10"s with just that. it was pretty incredible
Old Jun 11, 2009 | 12:31 AM
ninjaboy's Avatar
i thought that you could just use the av wire and hook up the amp directly to the deck and then connect the sub directly to the amp. is that not right?
Old Jun 11, 2009 | 04:33 PM
These stock HU do not have the aux. outputs on them. You have to run it from the speaker lines or buy a aux. output converter.
That pissed me off.
Old Jun 11, 2009 | 10:28 PM
apbbnbanb_07 you are wrong. An auxillary output is what we have in our cars for our MP3 players. What he needs is a Line Output Convertor. Which you can find at Future shop among other places. The way an amp goes to the deck is by RCA cables. And unfortunately there are no RCA hookups to the deck otherwise I would be much happier. Therefore you have to wire them up though the rear speakers in order to get the signal sent to the deck making it work. Its a pain in the *** but if you want to keep the stock deck then this is the way to go. There are people who have told me that they were going to tap into the speaker wires through the deck. I personally see that as a problem in case anything goes wrong *wire comes off or touches another wire etc* and its a lot easier to take a door panel off then the whole dashboard in order to get at the deck itself. I will be taking pictures of it when I help someone with it sometime soon.
Old Jun 11, 2009 | 11:04 PM
ninjaboy's Avatar
ok thanks
if i buy a new deck can i still use the steering wheel controls? lol
Old Jun 12, 2009 | 01:40 AM
nope. with that you loose those as well as the auxillary input. its not hard to do. just take a saturday and get it done
