Gas mileage for 2.5
Old Apr 3, 2012 | 01:38 PM
ElHatch12's Avatar
Talking Mazda 3 MPG
UseYourNoggin, could you provide a little more info about this spacer, do you know the year and engine size of the Fusion, also the thickness of the spacer would help me narrow down the results.
Old Apr 3, 2012 | 04:30 PM
You'll have to search for one on-line or your local performance shop. The Mazda V6 3.0 ltr is basically the same engine as the Ford Fusion so they interchange. That one will probably not fit on your 2.5 ltr 4 cylinder. Thickness is around 3/4". Another gasket and longer bolts are also required, and they do come with it. I am not sure if they even make one for the 2.5 ltr.
Good luck in searching.
If you change the O2 sensor, just change the one before the pre-cat (other one after pre-cat does not calibrate air/fuel mixture).
piper
Feb 15, 2009 11:22 AM
laplacian_operator
Jul 31, 2005 11:01 PM
taillite1989
Jul 9, 2005 03:07 PM
toysrme
Jun 30, 2005 07:22 PM
