Fog Light Upgrade
2007 Mazda 3i
my car did not come with fog lights and I am looking into adding them. I checked under the bumber and the wiring harness has the connectors for the fog lights. Also, in the fuse panel under the hood, there is a relay in the fog light spot. Could I just buy lights, hook them up and install the light switch with the button for the fog light and be good? I saw kits that had wires that needed to be run through the firewall, with grounds, wires that needed to be hot-wired to the ignition switch and so on, but I really don't want to go that route if i don't have to. So bottom line - can I just install a new OEM light switch (with fog light capability), and fog lights and be good - or is that not possible? |
