Error P0610 occurs ONLY below 10C
Hey Guys, new to the forums.
I have an error on my 2005 Mazda 3 1.6L Z6 , P0610, where this issue ONLY OCCURS BELOW 10C.
This issue causes my speedometer and odometer to not work. Therefore, my temporary solution for this is to wait until the engine reaches its operating temperature; turn the car off and then on again, and then everything works, however, I still have the Check Engine light showing as seen in the video.
So far what I’ve done to try and fix this issue (but have not been able to fix it) is;
Imagines: https://imgur.com/a/K6YsusU
Video: https://streamable.com/43k5nz
Any ideas and suggestions would be great apricated! Thanks,
- Heated up the PCB behind the dials and the fuses before startup.
- Changed the battery (New ones shows 12.82V Off & 14.8V On)
- New air intake filter
leftygolfguy
Nov 30, 2007 08:55 AM
