engine replacement for 2010 2.0 M3 - first gen?
Old Aug 3, 2020 | 10:43 AM
Frank Geo's Avatar
Default engine replacement for 2010 2.0 M3 - first gen?
Hello everyone,
I need to replace my engine (2010 2.0 Mazda 3).
Do you guys know if I could install a used 2005-2008 (first gen 2.0) on it without modification? Wikipedia says it's the same engine.
THANK YOU IN ADVANCE!
Old Aug 3, 2020 | 01:53 PM
Frank Geo's Avatar
Sorry and to clarify:
My car is 2010 generation 2 - Mazda 3 - 2.0L.
Can I install a gen 1 2.0L (2007). Any programming needed or modifications at all?
Wikipedia says it's the same engine....
A million thank you in advance if you can shed any light.
Old Aug 4, 2020 | 06:25 AM
You can use a 2007 engine. Use both manifolds off your 2010, along with all sensors and auxiliaries.
Old Aug 4, 2020 | 10:59 AM
Frank Geo's Avatar
thanks so much Grim!
and do you think that moving over manifolds, all sensors and auxiliaries would be a big deal for decent mechanic like just 1-2 extra hours?
I'm not a mechanic and trying to figure out if saving $500 on the engine would not cause too much in labor.
THANK YOU!
Old Aug 5, 2020 | 02:49 AM
You would be better off using a 2009 - 2011 engine. You would spend a couple of hours plus gaskets to swap , less than $500.
Old Aug 5, 2020 | 08:49 AM
If you do a swap change out of an engine I would recommend that you mention to the person doing it to carefully label EVERY electrical connection they disconnect. And to use a check sheet when re-installing checking off each electrical connection. I know this sound unusual but the most common thing of an engine swap out not starting is a forgotten connection.
Old Aug 5, 2020 | 12:16 PM
Frank Geo's Avatar
thanks so much guys!
The mechanic that is doing the job told me he'd prefer using the 2009-2011. That engine would cost me $400 more but in the end it's an easier job and hopefully better INSTALL. Fingers crossed!
rider2j
Off Road
Apr 18, 2020 08:43 PM
intoo
May 5, 2015 11:32 AM
deadeyedevon
Dec 6, 2011 03:59 PM
insaneMazda3i10
Feb 1, 2011 04:35 PM
phantomvs
Dec 30, 2008 02:10 PM
