CD Not Being Ejected
The CD player in my mazda 3 stopped ejecting CDs.
It tries to but gets stuck or stops before they come out.
Does anyone know if this is a common fault?
And if so, is there a fix? Or replacement is the only option?
I will try that thanks.
Usually what happens is the CD comes out a tiny bit, but if I press it in with another CD it will come out.
Are there any write ups on how to remove the head unit if need be?
Thanks
Thanks
not sure what year you have but on my girlfriends 07 3 the HU comes out pretty easily. All you have to do is open the glove box and put your fingers under the lip of that wood trim piece on the dash and pop it out from the center and move toward the drivers side. Once all the clips are popped out, you have to kind of slide the far passenger side edge towards the drivers side to get that piece off since it is hooked on that side. Then you will see 2 black screws on top of the HU's screen, remove those and pull out the player. Its held down by those 2 screws and a couple clips so it will take a little effort to release the clips.
I actually took hers out yesterday along with her center console. The 3 seems to be a very easy car as far as taking apart for installing things, atleast the 2007 is.
jaimie08mazda3
Mar 16, 2008 06:47 PM
