Is ATF M-V Mercon V??????
Thanks.
No.
Absolutely not. Totally different oils. You will kill your car if you use the wrong oil. |
What's the recommended oil?
What car do u have?
What engine? What transmission? |
o6 Mazda 5 2.3 auto
Mv atf
2.3 Ford/Mazda engines are the same. Do you think transmissions are different?
Finally!!!!!!!!!!!!!!!!! Found info! FNR5 FS5A-EL Ford/Mazda AT
http://www.carquestprofessionals.com...%206.10.13.pdf |
I strongly recommend only using Mazda MV ATF in your transmission.
